Hi everyone,
I wanted to create requirements from scratch on Capella, and i’ve followed this manual https://github.com/eclipse/capella-requirements-vp/blob/master/plugins/org.polarsys.capella.vp.requirements.doc/html/3_userguide/3a_edition.mediawiki#visualize-types , and I can’t find the “Capella Types Folder” on the "Add Capella Element " even after I unmatched “Requirement VP Types”.
I’m using Capella 5.0 and Requirement VP [v0.12.0].
Hi Amine,
Did you make sure that the VP is installed and activited/linked to the model?
Can you create a Capella Module and a Requirement?
Hi Stephane,
I’ve downloaded the VP zip file, extracted it on the dropins file and then i’ve executed capella. I don’t know if i’m missing a step.
You’ll find the missing steps in the help:
Help > Help content > Requirements Viewpoint Guide > User’s Guide > Viewpoint Manager
Thank you it’s working now, I should have opened the viewpoint manager and activate the reference, that was the only way to display the “Capella Types Folder” on the "Add Capella Element ".
Yes, as a more general comment, The Requirement Viewpoint is a “ViewPoint”, in Capella this means that you need to “activate it” on your model.
