Hi everyone,
I’m trying to create a physical function in Capella using Python4Capella, but it seems that the method get_owned_physical_functions does not exist to add a physical function to the Root Physical function.
Here’s an example of my code snippet:
pf_root = se.get_physical_architecture().get_physical_function_pkg().get_contents()[0]
print("pf_root: " + pf_root.get_name()) #get Root Physical Function
pfct = PhysicalFunction()
puid = uuid.uuid4()
pfct.set_id(str(puid))
date_heure = datetime.now().strftime("%Y%m%d_%H%M%S")
pfct.set_name(f"PF_{date_heure}")
pf_root.get_owned_physical_functions.add(pfct)
print("* Create a new Pf with name " + pfct.get_name() + " under " + pf_root.get_name())
Does anyone know how to create a physical function ?
Thanks in advance for your help!
Thierry
Hi Thierry,
You need to use get_owned_functions() which is the generic getter for all functions (logical, system, physical):
pf_root.get_owned_functions().add(pfct)
And don’t forget the parenthesis.
Thanks @YvanLussaud , it works.
Now I’m trying to create a functional exchange using get_incoming and get outgoing but I get an error. I also tried with get_inputs and get_outputs but i have the same error:
java.lang.UnsupportedOperationException
at org.eclipse.emf.common.util.BasicEList$UnmodifiableEList.add(BasicEList.java:908)
The source code is hereunder:
Pf1 = find_physical_function_by_name('PhysicalFunction 1',pf_root)
if not Pf1:
print ( 'NOT FOUND FROM: ' + str(Pf1))
else:
Pf2 = find_physical_function_by_name('PhysicalFunction 2',pf_root)
if not Pf2:
print ( 'NOT FOUND TO: ' + str(Pf2))
else:
pfip = FunctionInputPort()
pfip.set_name(f"PFIp_{date_heure}")
PhysicalFunction(Pf1).get_incoming().add(pfip)
pfop = FunctionOutputPort()
pfop.set_name(f"PFop_{date_heure}")
PhysicalFunction(Pf2).get_outgoing().add(pfop)
le = FunctionalExchange()
le.set_name(f"FE_{date_heure}")
le.set_source_port(pfop)
le.set_target_port(pfip)
Do you know what methods I should use?
Thanks in advance,
Thierry
I think incoming and outgoing ERefrences are derived (computed) and can’t be modified. You need to use inputs and outputs instead.
# you can also get an existing FunctionInputPort
f1.get_inputs().add(pfip)
# you can also get an existing FunctionOutputPort
f2.get_outputs().add(pfop)
fe = FunctionalExchange()
fe.set_target_port(pfip)
fe.set_source_port(pfop)
commonFunctionAncestor.get_java_object().getOwnedFunctionalExchanges().add(fe.get_java_object())
It works perfectly.
Thank you very much @YvanLussaud and have a great holiday season.
