You can use a small Python4Capella script, like this
# (c) Pier Giorgio Esposito, 2024
# name : Reverse Component Exchange
# script-type : Python
# description : Swap Source and Target of a Compoment Exchange
# popup : enableFor(org.polarsys.capella.core.data.fa.ComponentExchange)
if False:
include('workspace://Python4Capella/java_api/Java_API.py')
if False:
from java_api.Java_API import *
# include needed for the Requirement API
if False:
import logging
# configure logging format
logFormat = '%(asctime)-15s - %(processName)s - %(message)s'
logging.basicConfig(format=logFormat, level=logging.INFO)
logging.getLogger('py4j').setLevel(logging.ERROR)
# Retrieve the Element from the current selection
selElem = CapellaPlatform.getFirstSelectedElement()
c = ComponentExchange(selElem)
modelPath = CapellaPlatform.getModelPath(c)
aird_path = '/' + modelPath
model = CapellaModel()
model.open(aird_path)
logging.info('Model name: %s', se.get_name())
# preparing excel file export
project_name = aird_path[0:(aird_path.index("/", 1) + 1)]
project = CapellaPlatform.getProject(project_name)
# start transaction to make modifications in the model
model.start_transaction()
try:
logging.info(c.get_name())
sp = c.get_source_port()
logging.info(sp.get_name())
spj = sp.get_java_object()
logging.info(spj)
tp = c.get_target_port()
logging.info(tp.get_name())
tpj = tp.get_java_object()
logging.info(tpj)
cj = c.get_java_object()
logging.info(cj)
cj.setSource(tpj)
cj.setTarget(spj)
except:
model.rollback_transaction()
raise
else:
model.commit_transaction()
This script does not change the direction of the port, but it is easy to implement it.
