Please I have a question concerning the possibility of requirements diagram cration on capella, like what we can find on Cameo system modeler.
is it possible to create a requirement diagram directly on Capella without importing a requirement file generated from another tool, purpose is to represent requirement schematically? or at list create a requirement and add them to an existing system analysis diagram ?
Yes absolutely you can create from within Capella itself.
If you look at Help → Help Contents → Requirements Viewpoint Guide
You will have all the info/guidance you need.
Ah!, I just add the Requirement viewpoint add-on to Capella dropins file and now the guide is visible.
But I didn’t find the requirement option in the tool menu
Yes, i was opening a diagram when trying to activate de VP, now i closed it and retry and it works, i activate it and requirement window is now visible in the tool menu.
in order to add requirement ? can i write them directely in eany diagram i want or there is some restriction, sorry for those question, I am new in capella, I used to work on Cameo System modeler.
Have you an idea how can i have the title shown on head of requirement block, even if i write the title in requirement name case it does not appear in wright place
For type of the requirement link, where can I modify it plz ?
I can’t find those information on the guide
Thank you for your help, I follow the steps that you recommend me to do, but titles still don’t figure yet on the requirements block heads
What I’m trying to have is a representation like this
I’m not sure if naming requirements on this case called “Name” after clicking on requirement block allow title visibility on requirement block heads
for example in Cameo, just a simple click down on block make titling possible.
I am trying to install the Requirements Viewpoint (v0.14.0**)** add-on in my capella version (7.1, the latest available for download). I installed using the dropins method, and some features of a requirements tutorial that I was following are already available, as you can see in the image:
However, when I try to insert requirements on a diagram, for instance, my OAB, I do not see this option in the palette. I have checked the layers button and nothing is visible there. I have the “Capella Requirements” referenced in the Viewpoint Manager, but I don’t know how to include them in the diagram… Could you please help me?
