I downloaded capella for Mac but it’s impossible to open it.
Everyone can help me?
Thank you in advance,
Fanny Pruvot
Fanny Pruvot
Hi Fanny,
Please have a look here:
https://forum.mbse-capella.org/t/640/
And more importantly: make sure you have Java 1.8 installed, you can download it here
https://www.oracle.com/technetwork/java/javase/downloads/java-archive-javase8-2177648.html
You may have to uninstall newer java versions.
Hi Fanny,
I did everything as you told me however it still doesn’t work…
Thank you in advance for your help.
Sorry I put the wrong screenshot.
This is the good one
ok can you also share the log file that the popup is mentioning?
!SESSION 2020-06-09 15:44:21.246 -----------------------------------------------
eclipse.buildId=unknown
java.version=13.0.2
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=fr_FR
Framework arguments: -keyring /Users/pruvot/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -keyring /Users/pruvot/.eclipse_keyring
!ENTRY org.eclipse.core.net 1 0 2020-06-09 15:45:45.041
!MESSAGE System property http.nonProxyHosts has been set to local|.local|169.254/16|.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.egit.core 1 0 2020-06-09 15:45:45.179
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.osgi 4 0 2020-06-09 15:45:53.717
!MESSAGE An error occurred while automatically activating bundle org.polarsys.capella.core.sirius.analysis (635).
!STACK 0
org.osgi.framework.BundleException: Exception in org.polarsys.capella.core.sirius.analysis.activator.SiriusViewActivator.start() of bundle org.polarsys.capella.core.sirius.analysis.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:863)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:791)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1013)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:598)
at org.eclipse.osgi.container.Module.start(Module.java:462)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:493)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:570)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:330)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:396)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:474)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:415)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:155)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:620)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:196)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:934)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:139)
at org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:82)
at org.eclipse.sirius.business.internal.componentization.ViewpointRegistryImpl.initViewpointsFromPlugins(ViewpointRegistryImpl.java:709)
at org.eclipse.sirius.business.internal.componentization.ViewpointRegistryImpl.init(ViewpointRegistryImpl.java:194)
at org.eclipse.sirius.business.api.componentization.ViewpointRegistry$ViewpointRegistryHolder.(ViewpointRegistry.java:137)
at org.eclipse.sirius.business.api.componentization.ViewpointRegistry.getInstance(ViewpointRegistry.java:123)
at org.polarsys.kitalpha.ad.integration.sirius.Activator.start(Activator.java:55)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:554)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:834)
at org.polarsys.kitalpha.ad.services.ToolIntegrationHelper.loadTools(ToolIntegrationHelper.java:27)
at org.polarsys.capella.core.af.integration.AFDelegateWorkbenchAdvisor.preStartup(AFDelegateWorkbenchAdvisor.java:25)
at org.polarsys.capella.core.model.handler.advisor.DelegateWorkbenchAdvisor$Helper.callPreStartup(DelegateWorkbenchAdvisor.java:45)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaWorkbenchAdvisor.preStartup(CapellaWorkbenchAdvisor.java:132)
at org.eclipse.ui.internal.Workbench$19.runWithException(Workbench.java:1703)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:36)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:146)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4975)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2811)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:623)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:559)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaApplication.start(CapellaApplication.java:115)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:660)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1468)
Caused by: java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at org.polarsys.capella.common.tools.report.config.registry.ReportManagerRegistry.(ReportManagerRegistry.java:59)
at org.polarsys.capella.common.tools.report.config.registry.ReportManagerRegistry.getInstance(ReportManagerRegistry.java:111)
at org.polarsys.capella.core.commands.preferences.util.PreferencesHelper.(PreferencesHelper.java:71)
at org.polarsys.capella.core.commands.preferences.service.AbstractPreferencesInitializer.(AbstractPreferencesInitializer.java:36)
at org.polarsys.capella.core.sirius.analysis.preferences.DiagramPreferenceInitializer.(DiagramPreferenceInitializer.java:20)
at org.polarsys.capella.core.sirius.analysis.activator.SiriusViewActivator.start(SiriusViewActivator.java:73)
… 80 more
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException cannot be found by org.polarsys.capella.common.tools.report_1.4.0.201911211736
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:512)
… 90 more
Root exception:
… 90 more
!ENTRY org.eclipse.sirius.common 4 0 2020-06-09 15:45:53.731
!MESSAGE Impossible to load the extension
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.polarsys.capella.core.sirius.analysis was unable to load class org.polarsys.capella.core.sirius.analysis.activator.SiriusViewActivator.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:198)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.polarsys.capella.core.sirius.analysis (635).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
… 63 more
Caused by: org.osgi.framework.BundleException: Exception in org.polarsys.capella.core.sirius.analysis.activator.SiriusViewActivator.start() of bundle org.polarsys.capella.core.sirius.analysis.
… 73 more
… 80 more
… 90 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2020-06-09 15:45:53.736
!MESSAGE Plug-in org.polarsys.capella.core.sirius.analysis was unable to load class org.polarsys.capella.core.sirius.analysis.activator.SiriusViewActivator.
!STACK 0
… 73 more
… 80 more
… 90 more
!ENTRY org.eclipse.equinox.registry 4 1 2020-06-09 15:45:53.738
!STACK 0
… 73 more
… 80 more
… 90 more
!ENTRY org.eclipse.osgi 4 0 2020-06-09 15:45:53.779
!MESSAGE An error occurred while automatically activating bundle org.polarsys.capella.common.tools.report.appenders.usage (523).
!STACK 0
org.osgi.framework.BundleException: Exception in org.polarsys.capella.common.tools.report.appenders.usage.UsageAppenderPlugin.start() of bundle org.polarsys.capella.common.tools.report.appenders.usage.
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:41)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:470)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaWorkbenchAdvisor.preStartup(CapellaWorkbenchAdvisor.java:140)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.polarsys.capella.core.commands.preferences.util.PreferencesHelper
at org.polarsys.capella.common.tools.report.appenders.usage.preferences.PreferencesInitializer.(PreferencesInitializer.java:25)
at org.polarsys.capella.common.tools.report.appenders.usage.UsageAppenderPlugin.start(UsageAppenderPlugin.java:41)
… 42 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2020-06-09 15:45:53.833
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/polarsys/capella/common/tools/report/appenders/usage/UsageMonitoringLogger
java.version=13.0.2
!STACK 0
… 80 more
… 90 more
Root exception:
… 90 more
!STACK 1
… 63 more
… 73 more
… 80 more
… 90 more
!STACK 0
… 73 more
… 80 more
… 90 more
!STACK 0
… 73 more
… 80 more
… 90 more
!STACK 0
… 42 more
Root exception:
!STACK 1
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.polarsys.capella.common.tools.report.appenders.usage (523).
… 26 more
Caused by: org.osgi.framework.BundleException: Exception in org.polarsys.capella.common.tools.report.appenders.usage.UsageAppenderPlugin.start() of bundle org.polarsys.capella.common.tools.report.appenders.usage.
… 35 more
… 42 more
!ENTRY org.eclipse.core.jobs 2 2 2020-06-09 15:45:54.604
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.egit.ui.Activator$1
… 26 more
… 35 more
… 42 more
ok so the problem is that Capella is picking up java 13 instead of java 8.
You can see it at this line at the beginning of your log file: java.version=13.0.2
Try uninstalling this java version.
I downloaded java on your website
https://www.oracle.com/technetwork/java/javase/downloads/java-archive-javase8-2177648.html but it’s Java 13 and I didn’t find Java 8. I don’t know where I can find Java 8 version.
ok in the url you mentioned, you should look for this file to download and install: jre-8u121-macosx-x64.tar.gz
This is java 1.8 update 121 64 bits and this will work on Capella.
Before doing this, you should also uninstall java 13 from your machine.
