I try to change the capella physical component name depending on a selection made in PV.
I use the PV calculation. The calculation will be applied to the selected attribute: name:String.
the calculation is:
IF PVFEATURE->pv:Selected() THEN ‘OPTIE1’ ELSE ‘OPTIE2’ ENDIF
In Mappings shows
IF PVFEATURE->pv:Selected() THEN ‘OPTIE1’ ELSE ‘OPTIE2’ ENDIF = ‘OPTION2’ [TRUE]
??:?? - name: EString
But in the diagram or in the properties of the component, the name is not changed.
Do I miss something? Has someone experience with this?
Thanks in advance,
Kind regards,
Clemens
