Capella 7.1.0 has been released.
Discover all new interesting features in the dedicated page (Release Notes)
Capella 7.1.0 is available for download on the Capella website
Erwann
Erwann
The requirements viewpoint cannot be installed.
Solved it. Decencies were missing in my installation
Hi, how did you do it? And which problems did you have? I have been trying to install it for Capella 7.1.0 but I can’t seem to make it right…
On the update site of requirements viewpoint there are three extensions you need to download and install first. After this you can install the requirements viewpoint. If the update site does not work, use the drop-in.
Thanks for the reply! But how do I install those extensions? They redirect me to a page with some directories and files but then I don’t really know how to correctly install them…
Add the dependency p2 repository URLs directly under Help Install New Software or unpack zip drop-ins into your Capella dropins folder
Download the top “folder”
Hey, thanks for your replies! When I try to add the URLs after clicking in Help>Install New Software I get this error message:
"Unable to read repository at Eclipse software repository | The Eclipse Foundation
(certificate_unknown) PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target"
Do you know how to fix it?
Also, how do I download the top “folder”? I only see the icon to download the files at their lowest levels.
If the online p2 repository fails due to Java truststore restrictions, downloading the offline update site zip file and adding it via Help > Install New Software > Add > Archive bypasses SSL checks completely
