Capella 7.0.1 and Requirements Viewpoint v0.14.0
I’m new to Capella.
For a presentation I’ve to model the requirements of system.
After some research I discovered the Requirements Viewpoint is an add on to supplement the System Capabilities with Requirements.
I’ve downloaded the Requirements Viepoint v0.14.0 zip, unzipped it and copied the folder requirements to capella/ dropins.
After restart of Capella, I can select Requirements when starting a new project, but the requiremen part is nowhere showing.
If I select .aird and select Viewpoint Selection Capella Requirements is greyed out am I’m not able so select it.
I’ve tried to figure out why it is not working or what I’ve done wrong all day.
Has someone an idea how to fix it, so I’m able to use the add on?
I think it is not about selecting the aird but actually opening it and going into the first element in the model (or any below) and then activate the requirement viewpoint.
More info here: Documentation for activating the Requirements Viewpoint in the Viewpoint Manager: capella-requirements-vp/plugins/org.polarsys.capella.vp.requirements.doc/
Hey Stephane,
thanks for the Documencation.
You’re right about the activation.
It’s working now.
Thank you very much.
