Hi
I created a new Project and successfully created a few Operational Analysis diagrams. I did have some problems where I couldn’t create an Interaction in one diagram, but just moved on.
Now I’m in System Analysis and I can’t create any new diagrams under here. I first tried the Contextual System Actors diagram and the mouse pointer changes to busy, then returns to an arrow after 5 seconds or so.
I’m using 5.2. I found this error elsewhere on the web and it suggested it could be where it was located, so I have tried moving Capella to c:\capella. But no change.
Also tried re-installing VC++ redistributable (another suggestion). Also tried installing the latest JRE.
Checked the logs and found this.
!SESSION 2022-03-21 09:58:59.005 -----------------------------------------------
eclipse.buildId=unknown
java.version=14.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_AU
!ENTRY org.eclipse.egit.ui 2 0 2022-03-21 09:59:24.847
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: ‘C:\Users\ChrisGibbons’. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.ui 4 0 2022-03-21 09:59:33.311
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
at org.polarsys.capella.core.sirius.ui.actions.NewRepresentationAction.(NewRepresentationAction.java:70)
at org.polarsys.capella.core.explorer.activity.ui.hyperlinkadapter.AbstractCapellaNewDiagramHyperlinkAdapter.initNewRepresentationAction(AbstractCapellaNewDiagramHyperlinkAdapter.java:84)
at org.polarsys.capella.core.explorer.activity.ui.hyperlinkadapter.AbstractCapellaNewDiagramHyperlinkAdapter.createDiagram(AbstractCapellaNewDiagramHyperlinkAdapter.java:70)
at org.eclipse.amalgam.explorer.activity.ui.api.hyperlinkadapter.AbstractNewDiagramHyperlinkAdapter.linkPressed(AbstractNewDiagramHyperlinkAdapter.java:89)
at org.polarsys.capella.core.explorer.activity.ui.hyperlinkadapter.AbstractCapellaNewDiagramHyperlinkAdapter.linkActivated(AbstractCapellaNewDiagramHyperlinkAdapter.java:60)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:215)
at org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(ImageHyperlink.java:212)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:309)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.lambda$3(AbstractHyperlink.java:117)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4213)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4030)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1158)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1047)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaApplication.start(CapellaApplication.java:117)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
The same error occurs for:
- System Functions / Operational Activities Matrix
- System Actions / Operational Entities Traceability Matrix
- Functional Breakdown
- Functional Dataflow Blank
Any suggestions please?
