BPC shows shadow in PAB
Like the picture above, There has shadow in PAB when I create a new BPC (PC2) and deploy it to a NPC (PC1). The Capella project is newly created and version is 6.1. The display is right in Outline view.
The same problem appear when I switch to 6.0 version. SO, is there anything wrong with my computer? How can I fix this problem?
Thank you!
Hi Shawn, thank you for raising this issue. It’s not just your computer, I am seeing the same behaviour on PAB and LAB diagrams in both Capella 6.0 and 6.1. For LAB diagrams, the issue occurs when I nest a logical component (LC3 owned by LC1). Any solution to resolve this would be most welcome.
Jack
Dear Shawn and Jack,
I have the same problem as you. I see the shadows on both versions 6.0 and 6.1. And they are visible in the diagrams OAB and OCB. It happens on all operational entities, nested or not.
Have you managed to find a fix for the problem? How are you living with it?
Thank you!
Alexandre
You may want to look at this thread where a workaround is mentioned: Logical Architecture Diagram Component Rendering Issue - #4 by dmccammon
