Hello all,
I am working on M2DOC, and I am creating the template for extracting information from my model. I am working with CAPELLA 6.1, M2DOC 3.3.1 and on the “System Analysis” layer.
I would like to extract functions allocated to Actors & my System, and impossible to do that. In cause, the number of “allocatedFunctions” which is always equal to 0.
Here after my template:
with the above template when I add additional commands to access to other attributes, it works (for example: {m: CompoSys.actor} or {m:CompoSys.human}…)
Hello Yvan.
Thank you for your answer. I already tested that and it didn’t work.
And I know why now! Issue root cause found yesterday and sorry I did not take time to update my post :-(.
It seems the issue came from a bad “.genconf” file. Indeed, I re-edited a previous “.genconf” file (that I created from a previous version of M2DOC) into M2DOC 3.3.1, and it seems it has some strange behaviors regarding the variable targeted: long long time to load the variable, variable value some time not visible into “Generation configuration” window…).
What is strange it’s I had access to some attribute but not all…
Anyway, if I had followed the M2DOC use process, I wouldn’t have had this problem. My bad…
