Hi, I am quite new to Capella but I have built a few interesting models and I was interested in adding requirements to my diagrams. I have tried so far unsuccessfully to get the Requirements VP working. I downloaded the .tar file and went through the process of adding new software. When I went through this process I selected all the features? and hit next. It then told me there was a problem and it presented the following screen to me
From what I see, a bunch of features did not get installed. I do not know why, as I don’t know which OS/Capella version/VP Requirement version you tried to install, but for sure, the first CapellaRequirement feature should be installed (and probably other ones, I did not check)
I am not an expert of ‘Requirements’ but there is a lot of un-installed elements in the “Remediation Page”.
“Tests” and “CDO” are probably not important for you but “CapellaRequirements Feature” at least should be installed.
Can you try a fresh install and copy/paste here the errors you get when selecting “Show original error …” ?
You are possibly missing some components or have version conflicts.
I thought I would try to exclude the two features you mentioned above (Test & CDO). It also objected. Here is the Original error screen shot for that attempt.
The “Capella Requirements VP CDO feature” and the the “xHTML document generation for Requirement” features are extensions for Team for Capella and xHtml generation add-ons.
If those add-ons are not installed in your bundle, you do not need to select those features (nor the Test one).
I have tried the installation of Requirement VP on a freshly downloaded Capella 5.2 for macOS with the Requirement VP update site available at Project download area | The Eclipse Foundation
My installation steps:
Extract Capella from the downloaded archive
Run xattr -d com.apple.quarantine Capella.app
Use the Install new software wizard and select the Requirement VP downloaded update site.
From ViewpointManager, I can then reference the Requirement VP for a Capella project in my workspace and use Requirements
The Requirement VP User Manual is available in Help > Help Contents and then in Requirements Guide > User Manual (VP activation, UI configuration to allow the definition of Requirements, process to create and allocate Requirements, …
When I got home your reply had not reached me. So I was hunting around the forum and I came upon your reply. I tried it and it and it worked. I was going to update my topic when I realised it was actually the reply to my original request.
Anyway it seems the issue was the Requirements VP download.
I am just having a small problem adjusting the Labels in the Requirement diagram.
I have seen the instructions from Stephane to open the dialogue " Configure Requirements Labels in Diagram" but I cannot find the option described. It clearly has an expression for the Label and a different one for the Content.
I cannot get a Requirements diagram with a Title Label
If you need any help on the Requirement side in capella I’m happy to help.
We have implemented a full req model onto our capella with connecting requirements (product and derived into sw/hw) with test cases connected to them.
