Hey,
I’m trying to add a diagram element link into the description of our components. We have a large number of components and there is also a large number of diagrams that are used for each component.
I can obtain the diagrams of interest and write the diagram names into the description as text but can’t seem to find a useful function within the Capella Library that might help me achieve this. Is this possible to do?
For context, here is the function below in case anyone else wants to use this in the future.
# create hashmap of elements
sbs_elements = {}
for pkg in PCs:
for pab in pkg.get_owned_diagrams():
if pab.get_name() == sbs:
for comp in pab.get_represented_elements():
if "BehaviorPC" in str(comp) or "NodePC" in str(comp): # can use isinstance() here
sbs_elements[comp.get_name()] = [comp.get_description()]
# update hashmap with diagram names for each key
for diag in model.get_all_diagrams():
if "[PAB]" in diag.get_name() and "SBS" not in diag.get_name() and "SWBS" not in diag.get_name():
print(f"Checking {diag.get_name()}")
try:
for comp in diag.get_represented_elements():
comp_name = comp.get_name().split(':', 1)[0]
add_value_to_key(sbs_elements, comp_name, diag.get_name())
except:
print(diag.get_name(), "broken")
model.start_transaction()
try:
if diag.get_name() == diagram_name:
try:
print(f"{comp_name} current description: {comp.get_description()}")
print(f"Setting to new description {sbs_elements[comp_name]}")
desc = ""
for val in sbs_elements[comp_name]:
desc += val + "\n" # this doesn't actually add a new line...
comp.set_description(desc)
except:
pass
except:
print("Rollbacking transaction")
model.rollback_transaction()
raise
else:
print("committing transaction")
model.commit_transaction()
This is what I want to be able to automate and add into the description ^
I imagine there’s something that I can query that will allow me to find the diagram I’m interested in and then also just create the link with the diagram name as the title.
