Hello Sophie,
I apologize, but requirement.py has been modified, by adding new classes and implementing methods which were missing in Python4Capella addon.
Please find attached the updated script.
requirement.py (14.3 KB)
Please find below diffs
Pier Giorgio
--- requirement.py 2022-06-16 17:48:10.101859900 +0200
+++ /mnt/c/Users/piergiorgio.esposito/ws/capella_ws/Python4Capella/simplified_api/requirement.py 2021-12-13 10:06:22.000000000 +0100
@@ -161,15 +161,6 @@
self.get_java_object().setReqIFChapterName(value)
- def get_description(self):
- return self.get_java_object().getReqIFDescription()
- def set_description(self, value):
- self.get_java_object().setReqIFDescription(value)
def get_prefix(self):
@@ -188,27 +179,11 @@
self.get_java_object().setReqIFText(value)
def get_all_attributes(self):
+ status: KO
- res = []
- for child in self.get_java_object().eContents():
- specific_cls_name = child.eClass().getName()
- if (specific_cls_name == "StringValueAttribute") or \
- (specific_cls_name == "IntegerValueAttribute") or \
- (specific_cls_name == "EnumerationValueAttribute") or \
- (specific_cls_name == "BooleanValueAttribute") or \
- (specific_cls_name == "RealValueAttribute"):
- res.append(Attribute(child))
- return res
+ raise AttributeError("TODO")
def get_attribute(self, attributeName):
- for attr in self.get_all_attributes():
- if attributeName == attr.get_definition().getReqIFLongName():
- return attr
- return None
status: KO
@@ -247,12 +222,6 @@
res.append(specific_cls(capella_element))
return res
- def get_owned_relations(self):
- status: OK
- return create_e_list(self.java_object.getOwnedRelations(), AbstractRelation)
class Folder(Requirement):
@@ -271,155 +240,3 @@
return create_e_list(self.get_java_object().getOwnedRequirements(), Requirement)
-class Attribute(EObject):
- def __init__(self, java_object = None):
- if java_object is None:
- JavaObject.__init__(self, create_e_object("http://www.polarsys.org/kitalpha/requirements", "Attribute"))
- elif isinstance(java_object, Attribute):
- JavaObject.__init__(self, java_object.get_java_object())
- else:
- JavaObject.__init__(self, java_object)
- def get_definition(self):
- return self.get_java_object().getDefinition()
- def get_value(self):
- return self.get_java_object().getValue()
-class ReqIFElement(EObject):
- JavaObject.__init__(self, create_e_object("http://www.polarsys.org/kitalpha/requirements", "ReqIFElement"))
- elif isinstance(java_object, ReqIFElement):
- else:
-class AbstractRelation(ReqIFElement):
- raise ValueError("No matching EClass for this type")
- elif isinstance(java_object, AbstractRelation):
- else:
- def get_relation_type(self):
- return RelationType(self.get_java_object().getRelationType())
- def set_relation_type(self, value):
- self.get_java_object().setRelationType(value.get_java_object())
-class CapellaIncomingRelation(AbstractRelation):
- JavaObject.__init__(self, create_e_object("http://www.polarsys.org/capella/requirements", "CapellaIncomingRelation"))
- elif isinstance(java_object, CapellaIncomingRelation):
- else:
- def set_source(self, value):
- self.get_java_object().setSource(value.get_java_object())
- def set_target(self, value):
- self.get_java_object().setTarget(value.get_java_object())
-class CapellaOutgoingRelation(AbstractRelation):
- JavaObject.__init__(self, create_e_object("http://www.polarsys.org/capella/requirements", "CapellaOutgoingRelation"))
- elif isinstance(java_object, CapellaOutgoingRelation):
- else:
-class AbstractType(CapellaElement):
- JavaObject.__init__(self, create_e_object("http://www.polarsys.org/kitalpha/requirements", "AbstractType"))
- elif isinstance(java_object, AbstractType):
- else:
-class RelationType(AbstractType):
- JavaObject.__init__(self, create_e_object("http://www.polarsys.org/kitalpha/requirements", "RelationType"))
- elif isinstance(java_object, RelationType):
- else:
- @staticmethod
- def get_relation_types(architecture):
- res = []
- for fld in architecture.get_java_object().eContents():
- if fld.eClass().getName() == "CapellaTypesFolder":
- for rel in fld.eContents():
- if rel.eClass().getName() == "RelationType":
- res.append(RelationType(rel))
- return res
- @staticmethod
- def get_relation_type_by_name(architecture, name):
- for rel in RelationType.get_relation_types(architecture):
- if rel.get_name() == name:
- return rel
- return None
- def get_name(self):
- return self.get_java_object().getReqIFLongName()
