Were missions removed?
Also, here is a workaround:
You can change the image in your OCB diagram so that a Capability is shown as a Mission: Select an Operational Capability, click on the properties window, select the Appearance tab, and select the image icon (the one which says “Set style to workspace image”) and put the following path: /org.polarsys.capella.core.sirius.analysis/description/images/Mission.svg and click ok, that will do the trick.
I hope this helps.
Stephane
