I would like to change the appearance of my component in capella using the property “icon Path” of the properties view.
I put some icons in a plugin, but I don’t known how to reference it in the iconPath properties.
Hum, I am not sure about this icon path field.
The easiest way to set an image/icon is to use the appearance tab and select an image using the button as shown in the attached image. Before doing that, copy/import the image in your current project.
Thanks.
The icon Path is to change the default one.
For example if you want to change the icon of Physical Component to another one.
But it doesn’t work in this version of Capella 1.4
