Hello Capellers,
Here is the simple use case related to my question :
- I have defined REC1 in ‘MyCapellaLibrary’ library.
- I have instanciated a RPL1 of REC1 in ‘MyCapellaProject’ project.
- I change RPL1
- I try the ‘Update REC from selected RPL’ command on RPL1
The merge window is properly displayed, I can accept the change.
But in the end, the REC is not updated.
When I do the same change in the ‘MyCapellaLibrary’, then the REC is correctly updated.
Here is my question : is it possible to update a REC from a RPL in two different projects?
I can understand that it may be ‘dangerous’ to update a (shared) library from a project that is using it but I am in a case where that would help!
Benoit
