Florent R. wrote on Mon, 06 June 2016 07:40
I use the latest version of Capella (1.0.2) and whenever I try to install the Gendoc add-on I get this error :
Quote:
Cannot complete the install because one or more required items could not be found.
Software being installed: EGF Model Edit 1.3.0.v20151127-1606 (org.eclipse.egf.model.edit.feature.group 1.3.0.v20151127-1606)
Missing requirement: EGF Model Edit 1.3.0.v20151127-1606 (org.eclipse.egf.model.edit.feature.group 1.3.0.v20151127-1606) requires ‘org.eclipse.egf.model.edit.source.feature.group [1.3.0.v20151127-1606]’ but it could not be found"
I have followed the tutorial (update site) and already installed other add-on (Subsystem, Viewpoints etc…)
Does anyone have a clue to solve this error ?
Florent
Same problem here.
I still haven’t found the solution.
Here is my config if it can help :
Found a workaround here:
- Use (add) Eclipse Neon update site when installing a new software:
http://download.eclipse.org/releases/neon/ - Look for EGF (you can use the “type filter here” field:
–> Modelling->EGF SDK - Install EGF SDK.
NEON is using EGF version 1.4.0, but it seems to be ok. - After install it, use XHTML update-site package, and install the other packages (doesn´t need to install EGF now).
I did it with Capella 1.0.0, but it should work too with 1.0.2 (will try it later).
BR
