Quote:
- After the transition, did you get a dialog window informing you about some processing?
Nothing, just an hourglass ! Maybe i missed something
I made a video (attachment), it will be easier like this !
Quote:
ok, I have to admit I am very surprised then
Thanks for taking the time to create this video. I can reproduce on Mac OS X, but not on Windows X86. Don’t know about Windows 64bits.
Could you file a bug and attach the video in the Capella bugzilla?
https:// polarsys.org/bugs/buglist.cgi?component=Transition&produ ct=Capella&resolution=—
In the meantime, there is a very simple workaround: Commands in the Capella “Overview” tool are only shortcuts to commands available on model elements contextual menus. Here, you can launch your Functional Transition from any Function. Here you would typically choose “Root System Function” in the project explorer as a starting point.
can you tell us more about your environment:
I fill a bug here :
https://polarsys.org/bugs/show_bug.cgi?id=205 with my environment
I can’t attach the video (files are limited to 1Mo in bugzilla)
Yes, strange regression bug, I have the same issue…
Pascal, what is your environment, and JRE? Could you add this information in the bug that has been created in bugzilla?
Windows 8.1, x64
Java version 1.8.0_25
Thanks for the tip !
Just for information, the required jre is 1.7.0_60.
Try to switch to a new cleaned workspace before trying again the same use case with 1.7.0_60 jre.
