Hello everyone,
I started reading a bit more about the Java classes and found the SelectElementsFromTransferWizard one, which apparently is the one used to select many elements from a specific type of model. I wanted to create a similar dialog to open when my plugin handler is called, like so:
public class InitHandler extends AbstractHandler {
@Override
public Object execute(ExecutionEvent event) throws ExecutionException {
IWorkbenchWindow window = HandlerUtil.getActiveWorkbenchWindowChecked(event);
Collection<Session> col_Sessions = SessionManager.INSTANCE.getSessions();
List<String> str = new ArrayList<String>();
for (Session x : col_Sessions) {
java.lang.System.out.println(x.getID());
str.add(x.getID());
ElementListSelectionDialog diag = new ElementListSelectionDialog(window.getShell(), new LabelProvider());
diag.setElements(col_Sessions.toArray());
diag.setMessage("Please select the session (.aird file)");
diag.setTitle("Project Selection");
diag.setMultipleSelection(false);
Session result = null;
if (diag.open() == Window.OK) {
result = (Session)diag.getFirstResult();
else {
return null;
SelectElementsFromTransferWizard tranfer_Wizard = new(...)
// Do stuff with select elements here.
return null;
However, it seems that every usage of that class is, in fact, inside an .odesign file, and hacking a direct way to use it doesn’t seem the “Eclipse” way of doing it. Having said that, how should I use an odesign definition alongside my handler?
As an example, here is the oa.odesign tool definition:
<subModelOperations xsi:type="tool:ExternalJavaAction" name="Select Function" forceRefresh="true" id="org.polarsys.capella.core.sirius.analysis.actions.extensions.SelectElementsFromTransferWizard">
<parameters name="context" value="aql:container"/>
<parameters name="scope" value="aql:self.void2Null(container.getOESScopeInsertEntitiesRoles())"/>
<parameters name="initialSelection" value="aql:containerView.eContainerOrSelf(diagram::DDiagram).eAllContents(viewpoint::DSemanticDecorator).target->filter(interaction::InstanceRole).representedInstance"/>
<parameters name="wizardMessage" value=""/>
<parameters name="resultVariable" value="result"/>
</subModelOperations>
<subModelOperations xsi:type="tool:For" expression="aql:self.void2Null(result)">
<subModelOperations xsi:type="tool:If" conditionExpression="aql:i != 'WIZARD_CANCELED'">
<subModelOperations xsi:type="tool:ChangeContext" browseExpression="aql:container">
<subModelOperations xsi:type="tool:If" conditionExpression="aql:not (containerView.eContainerOrSelf(diagram::DDiagram).eAllContents(viewpoint::DSemanticDecorator).target->filter(interaction::InstanceRole).representedInstance->includes(i))">
<subModelOperations xsi:type="tool:CreateInstance" typeName="interaction.InstanceRole" referenceName="ownedInstanceRoles">
<subModelOperations xsi:type="tool:SetValue" featureName="representedInstance" valueExpression="aql:i"/>
<subModelOperations xsi:type="tool:SetValue" featureName="name" valueExpression="aql:i.name"/>
<subModelOperations xsi:type="tool:ChangeContext" browseExpression="aql:self.reorderInstanceRole(instance,predecessor)"/>
<subModelOperations xsi:type="tool:ChangeContext" browseExpression="aql:self.ensureCapabilityInvolvment(i.abstractType)"/>
