Hello!
For my masters dissertation I’m gathering evaluations of Capella. It would be a great help if you could in the following questionnaire: Microsoft Forms
Thank you very much!
Hello!
I myself did a masters dissertation around MBSE, so I understand you need to gather responses however I think more guidance is needed.
I think in order to get value and results that are meaningful you need to provide more context and explanation for each question. Plus, think about how this may be interpreted for a wide range of users from different industries etc.
As a result, I haven’t completed.
Hope this helps,
Josh
Hi!
Thank you very much for the reply! I understand your remarks and will give some more explanation in the form.
Thanks again
I added some information and some links that explain the ESA terms used.
If you have more remarks, please let me know!
Jan
