I’m currently working on Capella and so doing Exchange Scenarios. I’ve got an issue because while i’m working on completing my scenarios the timeline’s entites are expanded. Sometimes they end up very long for a short scenario sequence. Is there a possibility to reduce this timeline manually ?
Can you make a couple of screenshots/pictures of what you are trying to achieve?
Yes sure, for example you can see here that the timeline is much longer than needed. I’d like to be able to reduce the timeline length.
If you go at the bottom of your timeline, you should be able to select it and then bring it back up.
