I am on using Capella 5.2.0 and I have installed the v1.6.0 of the capella-sss-transition add-on using the dropin method.
I downloaded the correct dropin zip and copied the content in the already existing dropins directory in Capella installation folder.
The right-click option to do the “System to SubSystem Transition” is now available. I create a new project using the “SA Transition Options” window, the new project gets successfully created, but then when I click ok to proceed with the transition, the Diff/Merge dialog does not appear and simply nothing happens. The newly created project remains empty and no content is created from the original project.
I tried doing the transition by right-clicking the logical component both in a LAB diagram and in Project explorer, I tried Horizontal and Vertical SA transition, but nothing ever happens. Do you perhaps have an idea what might be the issue?
Thanks a lot.
Matej
