Hi All,
Today’s challenge for me is Enumeration Property Values.
Using the interpreter and “aql:self.value” shows the assigned ‘value’ of the EnumerationPropertyValue however when I attempt to print the value, either using the “get_value()” function or “PV.get_java_object().getValue()”, the console displays ‘None’.
Furthermore, if I try to export the value to excel, I see an error in the console pointing toward the functions above (error below).
“ValueError: Cannot convert JavaObject id=o757 to Excel”
Any alternative methods to print/ export the enumeration property value (as I have all other types working fine)?
Thank you!
