I have an issue while importing a ReqIF file into Capella (1.4.2 or 5.0)
If the ID field is including a ‘-’, e.g. ID = 1-2, Capella is reporting errors:
An internal error has occurred.
java.lang.NullPointerException
An internal error occurred during: “Load ReqIF resource”.
class java.lang.String cannot be cast to class java.math.BigInteger (java.lang.String and java.math.BigInteger are in module java.base of loader ‘bootstrap’)
This is a known issue when ReqIf is coming from a tool handling ID as string rather than numbers.
You can disable the ID import by disable it in preference.
