I would simply like to know if there is any way to get some requirement traceability tables directly in Capella > 1.3.x.
What I would like to get is a simple table containing the requirements ID/name in the first column, and the capella elements that satisfy those requirements in the second column.
Basically it would be something like that :
Reqmt | Satisfied by
REQ_1 | Node_1
REQ_2 | Function_7
REQ_3 | Functional_exchange_4
I hope that it is clear enough.
I already tried to obtain this by using the simple requirement legacy tools included in Capella, but both tables that I found useful (that are the requirement list and the requirement - system functions) do not correspond to that need, plus they are not customizable.
I then thought that something like this would be doable by using the requirement VP, but after reading all the documentation available in the help section I did not found any mention of something similar to what I’m looking for.
Is there any other way(s) to do this ? Maybe by using Mass Vizualisation tool ? Note that I do not specifically need to export this table at the end.
Thank you for reading,
