I noticed that pasting a Property Value Group into an element will not set automatically the “referencing elemnt” variable into the target element.
Meaning if you drag and drop the PVG into the diagram, the DEdge will not appear (no link between the element and its pvg in the diagram eventhough the pvg is “inside” it)
- Solution 1: Never copy paste PVG, instead make a new PVG and then copy the source properties from the first pvg into the the target pvg.
- Solution 2: is there a way to repair and “set” this value using some tool within Capella? (in case there was no other solution when copy pasting)
