I am trying to create an excel file to extract the functional analysis with the allocation on components (components are for me NodePC, not BehaviorPC, so I want to retrieve the NodePC from the function)
The problem is that at physical level, I can retrieve the BehaviorPC on which the function is allocated to (with method get_allocating_component() on the function). But, I cannot retrieve the NodePC on which the BehaviorPC is deployed, i.e. the “Deploying Physical Components” field.
I have tried to see the information that I can retrieved from the BehaviorPC by using get_all_contents, and I didn’t see the NodePC. Also, I have tried to use get_query_result(“Deploying Physical Components”) but the result was empty.
Is there a way to retrieve the name of the NodePC on which a BehaviorPC is deployed from the object BehaviorPC please ?
