Python4Capella installation issue
Hello everyone,
Issue when I try to install Python4Capella 1.3.0.qualifier on capella 6.1 ou 7.0.
I go to help/Install New Software… Then I select Python4Capella which is unzip (zip doesn’t work). I select inthe box Python4Capella (the both) & Python4Capella Command Line Interface and I have this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Python4Capella 1.3.0.qualifier (org.eclipse.python4capella.feature.feature.group 1.3.0.qualifier)
Missing requirement: Python4Capella 1.3.0.qualifier (org.eclipse.python4capella 1.3.0.qualifier) requires ‘osgi.bundle; org.eclipse.ease 0.8.0’ but it could not be found
Cannot satisfy dependency:
From: Python4Capella 1.3.0.qualifier (org.eclipse.python4capella.feature.feature.group 1.3.0.qualifier)
To: org.eclipse.equinox.p2.iu; org.eclipse.python4capella 0.0.0
Can you help me ?
Best regards.
The EASE 0.8.0 feature is in the update site you can find here. You can select all uncategorized features for your installation:
It should fix your installation issue.
Ok thanks I found the right package to get the same installation process than you :slight_smile:
