I’ve come across a bizarre bug with the use of python4capella.
I’m writing a script which exports the property values and some information about them into an xlsx file.
One of the pieces of information I need from each property value is the ‘Value’.
The simplified_api capella.py clearly shows the function ‘get_value’ exists and the function seems to work fine when called in my script.
BUT
The problem arises when the property value is a boolean type. The function get_value, when called, no longer works and the script fails to run with the error stating:
‘py4j.protocol.Py4JError: An error occurred while calling o34399.getValue. Trace:
py4j.Py4JException: Method getValue([]) does not exist’
Any advice or help to resolve this would be great,
Many thanks,
Angus
