I would like to use Basic performance and Quality Assessment (tutorial available on Youtube) viewpoints at the same time on a PAB diagram, but it seems there are some incompatibilities between these two viewpoints.
(you’ll find attached illustrations of these viewpoints)
When the two viewpoints are active :
- It is not possible to add a quality assessment element : when the quality assessment element is selected on the palette, it is impossible to add it on a node
- Existing quality assessment elements disappear (elements added when performance viewpoint was disabled from the diagram). Performance viewpoints elements stay visible. (see picture)
I also customized the viewpoint quality assessment so that I can add several bordered nodes on a quality assessment node. This time, when the two viewpoints are active on the diagram, all functions disappear and viewpoints elements (performance and quality assessment) stay visible.
Has someone a solution for this issue ?
Thanks for your help,
Lisa
