I’m working on a Capella 1.4.2 environment.
On a methodology that I try to define, I would like to have:
- 1 system model with model elements for all options and variants
- 1 subsystem model with model elements for all options and variants
- Possibility to transit system model elements into subsystem model elements with same options and variants
For that, I’ve started to use Filtering with following elements:
- 1 capella library with definition of filtering criteria and filtering results
- 1 capella project for system model using the capella library. Filtering criteria can be applied on the system model elements
- 1 capella project for subsystem model
Then, I’ve applied a system to subsystem transition to initiate subsystem model contents from system contents.
As a result, model contents are available on the subsystem model but without the criteria applied are lost.
Is it a known behavior? What can be proposed to transit the applied filtering criteria?
Benoit
