Hello, I’m a new Capella User. I used Interface scenario in the Physical layer. I can insert Sequence messages between an Actor and a Physical component (Yellow box). I was also able to add sequence messages from a Physical component to ITSELF but after sometimes I was not able anymore to insert NEW messages from the Physical component to ITSELF. The Dialog window “Create a Message without return” opens, I click on “create a new message”, I wrote the name of the message but When I click on “OK”, the dialog window doesn’t close. Nevertheless, with a NEW Physical component It worked. Did anybody encounter such issue?
Thanks for your help
Franck
Hello, I have the same problem on my model (Version 5.1). It’s possible on an another model but it doesn’t work for one.
Thank you for your help
Hello, I noticed that when the components/stakeholders used in the scenario are in subfolders or in different folders, it is not possible to add a sequence message. To fix this issue, I moved all the components used in the scenario in the same folder. The folder must be quite at a high level. When the scenario is done, I move back the components in their locations. I think it is a bug in Capella !
Thank you for your answer,
I tried your tips but it still doesn’t work. I have the error " Unhandled event loop exception".
Thank you,
