Import Same Physical Paths to another physical architecture Diagram
I created physical paths in one Physical Diagram, then I created the same physical diagram but with one solution (I mean I reduced the number of components), I want to import the same physical paths into my second physical diagram (as I do for functional chains), is there a way to do it ?
Hey Maissa,
You should be able to find it in the palette under “Node Components”. You might have to click the arrow next to “Physical Links” and slect “Physical Paths”. Then, click an empty space in your diagram and it should provide a list of available physical paths to insert.
Thanks a lot Dustin, I appreciate it! Yes, I confirm I found it and it worked :slight_smile:
