I think it is a very touchy issue … but I try.
Could it be possible to export Allocating Actor/Component (computed) to logical functions with Py4C? or by another mean?
thanks!
dvd
thanks!
dvd
To get the allocating actor/component, you can use:
myFunction.get_allocating_component()
There is also an API to call a query from the Semantic Browser:
capella_query_by_name(myFunction, "Allocating Actor/Component")
It seems that “myFunction.get_allocating_component()” exports the components which has been manually allocating to the function (using Allocation Management).
I would like to export every components “computingly” allocating by capella (Allocating Actor/Component (computed)) et not only (Allocating LogicalComponent).
Any Idea?
Did you try:
or
capella_query_by_name(myFunction, "Allocating Actor/Component (computed)")
Not sure what’s the real query name.
capella_query_by_name(myFunction, “Allocating Actor/Component”):
In fact I don’t know how to call this type of query? is it with python4capella with the aql interpreter ? something else?
With Python4Capella, myFunction is a variable referencing function that you can populate using the Python API. And of course you can get the result in a variable:
allocating_components = capella_query_by_name(myFunction, “Allocating Actor/Component”)
or directly loop over the resulting collection:
for allocating_component in capella_query_by_name(myFunction, “Allocating Actor/Component”):
print(allocating_component.get_name())
You can have a look at the definition of capella_query_by_name() for more details. For instance you can provide a default class for returned elements. This class will be used if the mapping form the Java class to the Python class can’t be done automatically.
