I am using the Graphical Query tool to extract data from Capella models.
I have attached an example of a simple query that I use to extract:
- the existing Physical Links at Physical Architecture level, and their ports/components and
- the allocated Component Exchanges and their ports/components.
The issue with this query is that only Physical Links allocating Component Exchanges will appear in the results.
Target: I would like to extract the Physical Links {with and without} Component Exchanges allocated with a single Graphical Query.
Do you have any tips to improve the Query/the pattern in .vql to achieve this target?
Apart from having two different queries, it seems not possible to realize what I am expecting. I would like to avoid this solution that requires to combine the output csv files afterwards.
P.S: I have tested the Mass Editing/Visualization prior to use the Query tool.
Thank you for your support.
Jay
