This seems to be a complicated function, I was wondering if such function existed anywhere. The function would return the Capella Element using it’s id.
We got this available code:
class CapellaElement(EObject):
A generic Capella model Element. Used to define generic attributes and relations inherited by most Capella elements
if java_object is None:
JavaObject.__init__(self, create_e_object("http://www.polarsys.org/capella/core/core/" + capella_version(), "CapellaElement"))
elif isinstance(java_object, CapellaElement):
else:
def get_id(self):
return self.get_java_object().getId()
def set_id(self, value):
self.get_java_object().setId(value)
I am imagining a function called “get_element”, that takes the Id as a parameter and returns the java object.
I checked, there is no module in Python4Capella for the time being (2022-08-01) for a fast implementation.
You can use following code:
include('workspace://Python4Capella/java_api/Capella_API.py')
if False: from java_api.Capella_API import capella_version
include('workspace://Python4Capella/java_api/EMF_API.py')
if False: from java_api.EMF_API import *
if False: from simplified_api.capella import *
include('workspace://Python4Capella/java_api/Sirius_API.py')
if False: from java_api.Sirius_API import Sirius
class CapellaSearch:
ME_ECLASS = get_e_classifier(
"http://www.polarsys.org/capella/common/core/" + capella_version(),
"ModelElement")
@staticmethod
def findById(model: CapellaModel, id: str) -> CapellaElement:
se = Sirius.get_system_engineering(model.session)
for value in e_all_contents(se):
if CapellaSearch.ME_ECLASS.isInstance(value) and value.getId() == id:
return EObject.get_class(value)(value)
for lib in model.get_referenced_libraries():
value = CapellaSearch.findById(lib, id)
if value is not None:
return value
return None
You can use it like this:
model = CapellaModel()
model.open('/C2M_TEST_01/C2M_TEST_01.aird') # change it
element = CapellaSearch.findById(model, "6de928a9-7fc6-485e-aec3-6cbb8c4aa026")
# Use 'expert' tab in 'Properties' of a CapellaElement
print("Python", element.get_name(), "type", type(element).__name__)
This solution has 2 limitations:
It only works for elements under ‘System Engineering’ (For example, PVMT configurations are not found)
it is very slow as every elements are tested in python.
This is a pretty ingenious solution, indeed it coudl get slow, but it has certainly its use. This is quite the important script I would say. @SPlazanet Maybe this one could go the library.
I thought of another “local” solution, i just save the ids of the items I am interacting with, and whenever I need to check the item with the id, i go check my saving. It’s faster but it only includes certain elements.
