Functional scenario, with function who need two or more functionnal exchange
I’ve got the following question.
In a Physical diagram i have two functions
ForumMBSE
I use two functional exchange in order to explicitly show all the data who come from PF1 and that PF2 need.
If I need to create a functional scenario, how to model the fact that the functional exchanges should be sent simultaneously by PF1 and receive simultaneously by PF2 ?
Hi @Amaury,
If you would like to capture in a scenario that both Functional Exchanges are sent at the same time you can use the fragment “PAR” and capture one Functional Exchange per partition.
I hope that helps,
Hélder Castro
Indeed, I had considered this solution, but for now I had put all the functional exchanges in the same part.
This may be a good idea.
But I don’t find it very elegant
ForumMBSE_01
