when I want to change the order of an element I right click on it then go to “Format” then move the mouse to the
“Order” field but when I’m arriving on it the full menu is disappearing ;-(
This occurs when I’m moving the mouse from the top of 'Order" field : when I’m arriving from the botton of the “Order” field this is working well and I’m able to select sub element (it depends how the menu is displayed from the element).
Did you already see this issue ?
Alex
Yes, I also have experienced this bug! it is really strange (and annoying…) when it happens !
I have noticed that if you go slowly, it doesn’t happen so much…
Dimitri
On which kind of element do you try to do that? (I tried to reproduce but did not succeed)
