I’m working on a Capella 1.4.2 environment.
On a MBSE methodology I try to define, I need a filtering library in order to be applied on many projects.
For that, I’ve created :
- 1 capella library with definition of filtering criteria and filtering results
- 1 capella project for system model using the capella library. Filtering criteria can be applied on the system model elements
Then, I display the model elements on diagram and I apply the Diagram Filtering criteria visibility.
When I select a Filtering result which has been defined on the library, there is nothing that happens on the diagram (no element that is displayed/undisplayed). It looks like that filtering results from library are disabled for visualization.
Is it a known behavior? What can be proposed to visaualize elements that corresponds to a “shared” filtering result ?
Benoit
