Using a new Capella 6.0.0 and the latest releases of the PVMT add-on and Python for capella, and also using Python 3.9 interpreter the script finally worked, I do not why I was having troubles before but anyway thanks for the help!
Hi, I am using this topic again because I have an issue with one of the scripts that you provided me before in this conversation.
I have used this script to extract attributes and values of requirements:
for req in se.get_all_contents_by_type(Requirement):
# Extracts Requirement Type
if req.get_java_object().getRequirementType() != None:
print("Type: "+req.get_java_object().getRequirementType().getReqIFLongName())
# Extracts Requirements Attributes and Values
if req.get_java_object().getOwnedAttributes() != None:
for att in req.get_java_object().getOwnedAttributes():
print("- Attribute: "+att.getDefinition().getReqIFLongName()+", value: "+str(att.getValue()))
With Capella 5.2 it was working but now on Capella 6.0 and a new model this error is being printed:
File "workspace://test_1/test_6.py", line 99, in <module>
if isinstance(value, integer_types):
File "C:\Users\Utente\Desktop\capella test 2\capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\java_gateway.py", line 1321, in __call__
File "C:\Users\Utente\Desktop\capella test 2\capella\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\protocol.py", line 330, in get_return_value
raise Py4JError(
py4j.protocol.Py4JError: An error occurred while calling o9779.getValue. Trace:
py4j.Py4JException: Method getValue([]) does not exist
at jdk.proxy15/jdk.proxy15.$Proxy28.executeScript(Unknown Source)
It seems that with some of the “req.get_java_object().getOwnedAttributes()” is not possible to use getValue, I tried also get_Value and getvalue and a few other functions but it didn’t work either
I think this is related to this issue:
Yes that was the problem, thank you!
