I used Capella Studio to create a new type of diagram and it was working well but suddenly I found that it throws the following exception, when I close the diagram and open it for 3 or 4 times (actually occurs when opening). Also, I have another diagram of the same type which has fewer objects in it and does not have such problem. Can it be because the diagram has many elements and is heavy? Any idea:
[code]
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine $4.run(PartRenderingEngine.java:1121)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine .run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRu nUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:610)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:148)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaAppl ication.start(CapellaApplication.java:116)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Dialog open exception:
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4559)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Display.error(Display.java:1262)
at org.eclipse.swt.widgets.Display.internal_new_GC(Display.java :2715)
at org.eclipse.swt.graphics.Device.getDepth(Device.java:454)
at org.eclipse.swt.widgets.Display.getIconDepth(Display.java:19 24)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:1005)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:1095)
at org.eclipse.jface.window.Window.configureShell(Window.java:3 68)
at org.eclipse.jface.dialogs.MessageDialog.configureShell(Messa geDialog.java:275)
at org.eclipse.jface.window.Window.createShell(Window.java:493)
at org.eclipse.jface.window.Window.create(Window.java:425)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1095)
at org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open (InternalErrorDialog.java:78)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.openQue stionDialog(IDEWorkbenchErrorHandler.java:190)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handleE xception(IDEWorkbenchErrorHandler.java:145)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.access$ 0(IDEWorkbenchErrorHandler.java:137)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler$1.runIn UIThread(IDEWorkbenchErrorHandler.java:112)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:97)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4211)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3827)
Error while informing user about event loop exception:
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Control.internal_new_GC(Control.java :1757)
at org.eclipse.swt.graphics.GC.win32_new(GC.java:5296)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:16 05)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4856 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5123 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:25 52)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3822)
at org.eclipse.swt.widgets.Control.new_GC(Control.java:2136)
at org.eclipse.swt.widgets.Widget.wmPaint(Widget.java:2313)
at org.eclipse.swt.widgets.Control.WM_PAINT(Control.java:5384)
at org.eclipse.swt.widgets.Label.WM_PAINT(Label.java:640)
!ENTRY org.eclipse.ui 4 0 2018-07-20 14:22:02.398
!MESSAGE Unhandled event loop exception
!STACK 0
!ENTRY org.eclipse.ui 4 0 2018-07-20 14:22:02.400
!MESSAGE Error occurred during status handling
!STACK 0
at org.eclipse.ui.internal.statushandlers.InternalDialog.config ureShell(InternalDialog.java:199)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialog ManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerI mpl.java:261)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialog ManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImp l.java:197)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.a ddStatusAdapter(WorkbenchStatusDialogManager.java:158)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStat usAdapter(WorkbenchErrorHandler.java:80)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.handle(W orkbenchErrorHandler.java:49)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handle( IDEWorkbenchErrorHandler.java:101)
at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(Wo rkbenchErrorHandlerProxy.java:31)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaStat usHandler.handle(CapellaStatusHandler.java:40)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusMan ager.java:204)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusMan ager.java:246)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusMan ager.java:257)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopExcepti on(WorkbenchAdvisor.java:330)
at org.eclipse.ui.internal.Workbench$3.eventLoopException(Workb ench.java:531)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine $4.handle(PartRenderingEngine.java:1143)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine $4.run(PartRenderingEngine.java:1133)
!ENTRY org.eclipse.ui 4 0 2018-07-20 14:22:14.398
!STACK 0
at org.eclipse.swt.custom.CTabFolder.setBackground(CTabFolder.j ava:2401)
at org.eclipse.e4.ui.css.swt.properties.custom.CSSPropertyUnsel ectedTabsSWTHandler.applyCSSProperty(CSSPropertyUnselectedTa bsSWTHandler.java:73)
at org.eclipse.e4.ui.css.swt.properties.AbstractCSSPropertySWTH andler.applyCSSProperty(AbstractCSSPropertySWTHandler.java:3 3)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.app lyCSSProperty(AbstractCSSEngine.java:762)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.app lyStyleDeclaration(AbstractCSSEngine.java:548)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.app lyStyles(AbstractCSSEngine.java:414)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.app lyStyles(AbstractCSSEngine.java:363)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.applySt yles(ThemeEngine.java:516)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine $6.setClassnameAndId(PartRenderingEngine.java:1288)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.se tCSSInfo(SWTPartRenderer.java:112)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.update NonFocusState(WBWRenderer.java:684)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.access $6(WBWRenderer.java:661)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer$9.hand leEvent(WBWRenderer.java:655)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1084)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1709)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2277)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4796 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1656)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2199)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5110 )
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3819)
