Hi all,
I am new to Capella, let alone to MBSE.
I downloaded the latest Linux verison of Capella from the official website.
With that, I also downloaded all open-source/free add-ons to it, installed it the way the instructions said to do.
Now, once I launch Capella, I already get the first errors without doing anything:
ExtensionPointHelper.createsInstance(..) _ Unable to instantiate class type:org.polarsys.capella.vp.requirements.Requirements.provider.CapellaRequirementsItemProviderDecoratorAdapterFactory |
Error |
null |
3:29:50 PM
ExtensionPointHelper.createsInstance(..) _ Unable to instantiate class type:org.polarsys.kitalpha.vp.requirements.Requirements.provider.RequirementsItemProviderDecoratorAdapterFactory |
Error |
null |
3:29:50 PM
ExtensionPointHelper.createsInstance(..) _ Unable to instantiate class type:org.polarsys.capella.cybersecurity.model.edit.decorators.CybersecurityItemProviderDecoratorAdapterFactory |
Error |
null |
3:29:50 PM
ExtensionPointHelper.createsInstance(..) _ Unable to instantiate class type:org.polarsys.capella.vp.requirements.id.handler.IdentifiableElementIdHandler | Error | | null | | | 3:30:00 PM
In an existing model, let’s say in an Operational Capabilities window, if I delete an Involvement Relationship link between an Operational Capability and an Operational Entity, I get:
Plug-in org.polarsys.capella.cybersecurity.helpers was unable to load class org.polarsys.capella.cybersecurity.helpers.CyberSecurityDeleteHelper. | Error | | null | | | 3:41:42 PM
If I again create the link between the same elements, nothing happens.
In an Operational Activities window, if I create an Activity, I get:
ExtensionPointHelper.createsInstance(..) _ Unable to instantiate class type:org.polarsys.capella.cybersecurity.ui.contribution.menu.CybersecurityConfigurationContribution | Error | | null | | | 3:46:47 PM
creating an Interaction between two Activities causes:
ExtensionPointHelper.createsInstance(..) _ Unable to instantiate class type:org.polarsys.capella.cybersecurity.ui.contribution.menu.CybersecurityConfigurationContribution | Error | | null | | | 3:48:09 PM
With all of that, I am able to build schemes. I am following Capella youtube channel’s tutorials, thus I haven’t tried to do more serious stuff yet. However, I am concerned by the amount of the errors produced by those simple manipulations.
I am attaching here my capella.ini file. I did install the latest, 19th and the 17th version of JDK from Adoptium and added the -vm /path/to/temurin_java_bin/java, changed the line with the required version number (19, then 17), but nothing has noticebly changed in Capella’s work. I also tried the same for the openjdk 19.0.2 already available in the Linux’ official repositories, but alas.
-startup
plugins/org.eclipse.equinox.launcher_1.6.200.v20210416-2027.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.2.200.v20210429-1609
-vm
/usr/bin/java
-vmargs
-Dosgi.requiredJavaVersion=19
-Dosgi.dataAreaRequiresExplicitInit=true
-Dpde.jreProfile=JavaSE-19
-Xms1000m
-Xmx3000m
-Xss4m
Some error lines from a log-file:
!ENTRY org.polarsys.capella.filtering.properties 4 2 2023-01-21 21:28:27.492
!MESSAGE Section org.polarsys.capella.filtering.properties declares non-existing filter or section class.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.polarsys.capella.filtering.properties was unable to load class org.polarsys.capella.filtering.properties.sections.CapellaFilteringPropertySection.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:198)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:920)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.ui.internal.views.properties.tabbed.view.SectionDescriptor.getFilter(SectionDescriptor.java:139)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistryClassSectionFilter.appliesToSelection(TabbedPropertyRegistryClassSectionFilter.java:78)
at org.eclipse.ui.views.properties.tabbed.AbstractSectionDescriptor.appliesTo(AbstractSectionDescriptor.java:57)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistry.adaptDescriptorFor(TabbedPropertyRegistry.java:316)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistry.filterTabDescriptors(TabbedPropertyRegistry.java:295)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistry.getTabDescriptors(TabbedPropertyRegistry.java:282)
at org.polarsys.capella.common.flexibility.wizards.ui.tabbed.FixedTabDescriptorProvider.getTabDescriptors(FixedTabDescriptorProvider.java:81)
at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistry.getTabDescriptors(TabbedPropertyRegistry.java:278)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.getLastTabSelection(TabbedPropertySheetPage.java:634)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.setInput(TabbedPropertySheetPage.java:736)
at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.selectionChanged(TabbedPropertySheetPage.java:555)
at org.eclipse.gmf.runtime.diagram.ui.properties.views.PropertiesBrowserPage.selectionChanged(PropertiesBrowserPage.java:254)
at org.eclipse.ui.views.properties.PropertySheet.showSelectionAndDescription(PropertySheet.java:562)
at org.eclipse.ui.views.properties.PropertySheet.partVisible(PropertySheet.java:435)
at org.eclipse.ui.part.PageBookView$1.partVisible(PageBookView.java:1040)
at org.eclipse.ui.internal.WorkbenchPage$17.run(WorkbenchPage.java:5217)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.ui.internal.WorkbenchPage.firePartVisible(WorkbenchPage.java:5214)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partVisible(WorkbenchPage.java:257)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$5.run(PartServiceImpl.java:297)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartVisible(PartServiceImpl.java:294)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:110)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5996)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.lambda$4(StackRenderer.java:975)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:84)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5879)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1427)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1453)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1436)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1225)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3243)
at org.eclipse.swt.custom.CTabFolder.destroyItem(CTabFolder.java:811)
at org.eclipse.swt.custom.CTabItem.dispose(CTabItem.java:132)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.hideChild(StackRenderer.java:908)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:359)
at jdk.internal.reflect.GeneratedMethodAccessor13.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:92)
at org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch(NotificationImpl.java:1027)
at org.eclipse.emf.common.notify.impl.NotificationImpl.dispatch(NotificationImpl.java:1032)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.remove(NotifyingListImpl.java:718)
at org.eclipse.emf.common.util.AbstractEList.remove(AbstractEList.java:456)
at org.eclipse.e4.ui.workbench.addons.dndaddon.StackDropAgent.dock(StackDropAgent.java:350)
at org.eclipse.e4.ui.workbench.addons.dndaddon.StackDropAgent.drop(StackDropAgent.java:434)
at org.eclipse.e4.ui.workbench.addons.dndaddon.DragAgent.dragFinished(DragAgent.java:172)
at org.eclipse.e4.ui.workbench.addons.dndaddon.PartDragAgent.dragFinished(PartDragAgent.java:111)
at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.finishDrag(DnDManager.java:266)
at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.startDrag(DnDManager.java:233)
at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.lambda$0(DnDManager.java:84)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:131)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:5121)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4599)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.polarsys.capella.core.platform.sirius.ui.app.CapellaApplication.start(CapellaApplication.java:118)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:654)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1462)
at org.eclipse.equinox.launcher.Main.main(Main.java:1435)
Caused by: java.lang.ClassNotFoundException: org.polarsys.capella.filtering.properties.sections.CapellaFilteringPropertySection cannot be found by org.polarsys.capella.filtering.properties_1.6.1.qualifier
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:519)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:170)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:520)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:622)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:196)
... 114 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2023-01-21 21:28:27.492
!MESSAGE Plug-in org.polarsys.capella.filtering.properties was unable to load class org.polarsys.capella.filtering.properties.sections.CapellaFilteringPropertySection.
!STACK 0
I would very much appreciate any advice on this matter.
Mike
