I am attempting to use the get_do function under the State class however I receive an error when I use it that the Method doesn’t exist has anyone else received this error?
This is my code, where elem_ms is a Mode or State object:
involved_do_SysFnc = elem_ms.get_do()
This is the error which is returned:
File “workspace://Python4Capella/sample_scripts/Export_system_functions_to_xslx.py”, line 187, in
module = _pyease_ast.Module(tree.body[:-1], type_ignores=[])
File “workspace://Python4Capella/sample_scripts/Export_system_functions_to_xslx.py”, line 109, in getModesandStates
# Strings can be send directly
File “workspace://Python4Capella/simplified_api/capella.py”, line 1914, in get_do
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\java_gateway.py”, line 1322, in call
answer, self.gateway_client, self.target_id, self.name)
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\protocol.py”, line 332, in get_return_value
format(target_id, “.”, name, value))
py4j.protocol.Py4JError: An error occurred while calling o1734.getDo. Trace:
py4j.Py4JException: Method getDo([]) does not exist
at com.sun.proxy.$Proxy30.executeScript(Unknown Source)
