I have enabled EPBS on my capella model. After finishing the physical architecture, I wanted to create a hierarchy of configuration items and show how they relate. I am not able to use “contained in” and tie the relevant configuration items. Did I miss an add-on of some sort?
Indeed the Contained In doesn’t work.
It seems broken when the diagram is created directly under the Structure package.
If the breakdown diagram is located under the default SystemCI, it works.
To define composition of CI, you can also use the EAB (EPBS Architecture Blank Diagram)
I have created an issue for this. #2229
Philippe
Thank you and unfortunately none of your suggestions worked. All I created is under System CI System and not sure why I cannot click on COTSCI1 for instance and then click on contained in and point to System CI System.
