Hi! Is it possible for Capella to generate different views depending on the discipline? For example, a mechanical engineer would prefer a certain view while a software engineer would prefer a whole different view.
The simplest way is to create multiple diagrams dedicated to who is going to consume them. For example, you would create a master Architecture diagram, then clone it, then rename the clone diagram so that it is targeted to your audience, and activate/deactivate the right filters and hide the elements that are appropriate for them.
Another more complex way is to use Capella Viewpoints. The Cybersecurity viewpoints is a good example, when you activate it, you get extended diagram capacities dedicated to Cybersecurity users.
