I usually set the appearance of diagrams with rulers, grid enabled and dot style for grid. While it is possible to enable/disable rulers and grid from Windows | Preferences | Sirius, I cannot find any way to set the grid style.
Is there any way to set it with some properties in the project configuration?
By “grid style”, do you mean the grid line and color as found in the Rules & Grid property tab for a given diagram?
Hi Stephane, you got my point.
I would like these preferences to be assigned by default, instead of modifying them for each new diagram.
Pier Giorgio
ok, so I am sorry the answer is no. There is no way at the moment to change these preferences either from the UI or from some project preferences or plugin initialization. These 2 settings are managed differently (by GMF, one of the underlying graphical frameworks that Sirius relies on) than the other settings. and the only way would be to change some code - to be tested - let us know if you would be interested to head into this direction, this would involve some professional service from us.
