I’m only able to debug a script below the include lines in a workspace if the variable tab isn’t open. As soon as I open the variable tab, the debug will terminate. This is an error message I received on the console after attempting to debug the list logical components sample script:
py4j.Py4JException: An exception was raised by the Python Proxy. Return Message: Traceback (most recent call last):
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\clientserver.py”, line 581, in _call_proxy
- return_value = getattr(self.pool[obj_id], method)(params)
- File “<…>”, line 424, in run*
- File “C:\Users\fhewson\Documents\Python37\Python37\lib\bdb.py”, line 578, in run*
- exec(cmd, globals, locals)*
- File “__ref_L/Python4Capella/sample_scripts/list_logical_components.py_ufqosnensf”, line 33, in *
- import main*
- import main*
- File “<…>”, line 231, in trace_dispatch*
- File “C:\Users\fhewson\Documents\Python37\Python37\lib\bdb.py”, line 88, in trace_dispatch*
- return self.dispatch_line(frame)*
- File “C:\Users\fhewson\Documents\Python37\Python37\lib\bdb.py”, line 112, in dispatch_line*
- self.user_line(frame)*
- File “<…>”, line 241, in user_line*
- File “<…>”, line 296, in dispatch*
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\java_gateway.py”, line 1322, in call*
- answer, self.gateway_client, self.target_id, self.name)*
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\protocol.py”, line 328, in get_return_value*
- format(target_id, “.”, name), value)*
py4j.protocol.Py4JJavaError: An error occurred while calling o0.traceDispatch.
: py4j.Py4JException: An exception was raised by the Python Proxy. Return Message: Traceback (most recent call last): - File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\org.eclipse.ease.lang.python.py4j_0.8.0.I202104091518\pysrc\ease_py4j_main.py”, line 132, in convert_value*
- return converter.convert(value, gw)*
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\java_collections.py”, line 511, in convert*
- java_list.add(element)*
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\java_gateway.py”, line 1313, in call*
- args_command, temp_args = self._build_args(args)
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\java_gateway.py”, line 1283, in _build_args*
- [get_command_part(arg, self.pool) for arg in new_args])*
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\java_gateway.py”, line 1283, in *
- File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\protocol.py”, line 298, in get_command_part*
- command_part = REFERENCE_TYPE + parameter._get_object_id()*
AttributeError: type object ‘int’ has no attribute ‘_get_object_id’
During handling of the above exception, another exception occurred:
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\py4j-python_0.10.9.3-bnd-2odeag\src\py4j\clientserver.py”, line 581, in _call_proxy*
File “<…>”, line 122, in getVariables*
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\org.eclipse.ease.lang.python.py4j_0.8.0.I202104091518\pysrc\ease_py4j_main.py”, line 117, in convert_value*
for k, v in value.items()*
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\org.eclipse.ease.lang.python.py4j_0.8.0.I202104091518\pysrc\ease_py4j_main.py”, line 117, in *
File “C:\Users\fhewson\Documents\Capella 1.4.2\Capella 1.4.2\eclipse\plugins\org.eclipse.ease.lang.python.py4j_0.8.0.I202104091518\pysrc\ease_py4j_main.py”, line 133, in convert_value*
except Exception:*
TypeError: catching classes that do not inherit from BaseException is not allowed -
at py4j.Protocol.getReturnValue(Protocol.java:476)*
at py4j.reflection.PythonProxyHandler.invoke(PythonProxyHandler.java:108)*
at com.sun.proxy.$Proxy33.getVariables(Unknown Source)*
at org.eclipse.ease.lang.python.debugger.PythonDebugger$PythonDebugFrame.getVariables(PythonDebugger.java:83)*
at org.eclipse.ease.lang.python.py4j.internal.Py4jDebuggerEngine.getVariables(Py4jDebuggerEngine.java:123)*
at org.eclipse.ease.debugging.AbstractEaseDebugger.handleEventsInSuspendedState(AbstractEaseDebugger.java:300)*
at org.eclipse.ease.debugging.AbstractEaseDebugger.suspend(AbstractEaseDebugger.java:255)*
at org.eclipse.ease.lang.python.py4j.internal.Py4jDebugger.suspend(Py4jDebugger.java:87)*
at org.eclipse.ease.debugging.AbstractEaseDebugger.processLine(AbstractEaseDebugger.java:490)*
at org.eclipse.ease.lang.python.debugger.PythonDebugger.traceDispatch(PythonDebugger.java:177)*
at sun.reflect.GeneratedMethodAccessor39.invoke(Unknown Source)*
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)*
at java.lang.reflect.Method.invoke(Method.java:483)*
at py4j.reflection.MethodInvoker.invoke(MethodInvoker.java:244)*
at py4j.reflection.ReflectionEngine.invoke(ReflectionEngine.java:357)*
at py4j.Gateway.invoke(Gateway.java:282)*
at py4j.commands.AbstractCommand.invokeMethod(AbstractCommand.java:132)*
at py4j.commands.CallCommand.execute(CallCommand.java:79)*
at py4j.ClientServerConnection.sendCommand(ClientServerConnection.java:244)*
at py4j.CallbackClient.sendCommand(CallbackClient.java:384)*
at py4j.CallbackClient.sendCommand(CallbackClient.java:356)*
at py4j.reflection.PythonProxyHandler.invoke(PythonProxyHandler.java:106)*
at com.sun.proxy.$Proxy32.run(Unknown Source)*
at org.eclipse.ease.lang.python.py4j.internal.Py4jDebugger.execute(Py4jDebugger.java:106)*
at org.eclipse.ease.lang.python.py4j.internal.Py4jDebuggerEngine.internalExecute(Py4jDebuggerEngine.java:85)*
at org.eclipse.ease.lang.python.py4j.internal.Py4jScriptEngine.execute(Py4jScriptEngine.java:227)*
at org.eclipse.ease.AbstractScriptEngine.inject(AbstractScriptEngine.java:189)*
at org.eclipse.ease.AbstractScriptEngine.run(AbstractScriptEngine.java:242)*
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)*
