Does anyone know what is the method to create a note in a Diagram ? Or how can I create a note in a Diagram by code ? If I well understand, I have to create a Node and set the style of it to Note and then insert it in the concerned diagram right ? But I did not succeed.
Hello
At the top of the Palette, in every diagram editor, you will find tools to add:
- Notes, which are similar to comments to the diagram
- Text
- Representation links, which are notes that allow you to navigate to other diagrams
Hope it helps
Hello
Thank you for your help but I’m trying to do it by code.
