I tried the merge function, but the element in different project still not shown together, could you explain more how to merge different element in one project?
You can refer to the embedded documentation for detailed explanations regarding the use of the diff/ merge function.
(Help / Help Contents, then Capella Guide, User Manual, Model DiffMerge)
Basic steps are:
- select two models, Compare With / Each Other as models
- then, you will get the following view
- use the button highlighted below in order to transfer elements from one model to another
- save in order to apply the modifications on the models
Don’t hesitate to ask if you have more questions!
If ever you are talking about what I presented in the webinar (i.e. merging from two completely different projects) there is an extensive section dedicated to this topic in the embedded Help of Capella version 1.2 (EMF Diff/Merge Guide - User’s Guide - Configuring a comparision). If you still have questions after that we’ll be happy to try and answer them.
